What gives with the Edit function? http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=4141 |
Author: | Howard Klepper [ Fri Dec 16, 2005 4:22 pm ] |
Post subject: | |
I regularly have gotten a message saying that there is a problem with the size of the field when I try to edit. When this happens, no amount of change to the edit ever helps. What's up with that? |
Author: | JJ Donohue [ Fri Dec 16, 2005 5:53 pm ] |
Post subject: | |
Howard...I can't help with the edit function...but your posts are usually so well composed and articulate...I'm surprised you'd even need the edit function!!! ![]() |
Author: | RussellR [ Fri Dec 16, 2005 8:28 pm ] |
Post subject: | |
Howard it is usually that the system has added too many re's in the subject line edit the subject line and it should be ok |
Author: | Brock Poling [ Sat Dec 17, 2005 12:16 am ] |
Post subject: | |
What Russell said..... When you are struggling try changing the subject line. Also, if you are having specific problems PM me when you are having them and perhaps I can duplicate the problem. Once I can duplicate it that will help us pin point where to fix it. :_) |
